Display OSPF authentication information to ensure accuracy.
View the OSPF authentication information:
Switch:1#show ip ospf int-auth
                     OSPF Interface AuthKey - GlobalRouter
INTERFACE       AUTHTYPE AUTHKEY
192.0.2.1       none
192.0.2.11      none
192.0.2.3       none
Variable definitions
The following table defines parameters for the show ip ospf int-auth command.
| Variable | Value |
| vrf WORD<1-16> | Specifies a VRF by name. |
| vrfids WORD<0-512> | Specifies a range of VRF IDs. |
